1 inch brass union compression fitting?
cmose
Indiana
Does anyone know anywhere online that I could purchase a 1 inch brass union with ferule and compression nut? I've got a whole house water filter housing with 1 inch female ports and was planning on using a brass compression fitting it hook it into the 1 inch copper household plumbing. Haven't found a plumbing supply in my area that carries anything above 3/4'' brass unions/fittings.
Barring that, any better suggestions for hooking in the water filter housing?
Forgot to mention, local plumbing supply sold me a pair of these (same fitting listed here https://terrylove.com/forums/showthread.php?41471-What-kind-of-union-fitting-is-this-Ford-Fitting) and suggested I use those instead. Good idea/bad idea?
Cacher_Chick
Test, Don't Guess!
I have not seen 1" CTS compression fittings.
For water filters, I like copper male sweat unions.
Hackney plumbing
Homeowner
Alabama
Try a good hydraulic and instrumentation fitting supplier. The fitting is made.
cmose
Indiana
Thanks! Is there any particular reason NOT to use the fittings I linked to in the initial post? I already have the things so I'm tempted to use them if they'll do the trick.
