1 circuit/2 gang 3 way switches- Does this look right?
Discussion in 'Electrical Forum discussion & Blog' started by cbailey, Apr 17, 2014.
  1. cbailey
    cbailey New Member
    Apr 17, 2014
    WI
    Hi All-
    Would appreciate any feedback about the attached diagram.
    I'm not a homeowner working on a basement finish project and want to have my plans tight before submitting for a permit.
    Any guidance is much appreciated!
  2. hj
    It looks good, but would look less like a "plate of spaghetti" if you had left the green wires out and just said everything will be grounded. In fact, if you use plastic devices, you will not be connecting the grounds to the boxes anyway.
  4. ActionDave
    ActionDave Electrician
    Feb 4, 2009
    Electrician
    Colorado
    What you have will work but I would bring power directly to the switches in the bottom box, two wire switch leg to each set of lights out of the switch box and only run the three wire from switch to switch.
  5. hj
    quote; I would bring power directly to the switches in the bottom box
    That would be a personal preference, and might depend on the physical arrangement of the wires relative to the boxes.
  6. ActionDave
    Feb 4, 2009
    Electrician
    Colorado
    One more reason to do it besides personal preference is it is the easiest way to comply with recent code requirement to have a neutral at every switch. 2014 code has backed off on some of the locations but the rule still exists.
  7. hj
    quote; it is the easiest way to comply with recent code requirement to have a neutral at every switch.
    It is a "dumb" requirement, and it is only "easier" if it is "easy" to run a two wire to the switch location. In many instances that would require a 3 wire to the switch, it the leg is being dropped out of the fixture to the switch.
  8. ActionDave
    Feb 4, 2009
    Electrician
    Colorado
    I agree.
    Those instances are very rare when you are starting from scratch.
  9. bluebinky
    bluebinky Member
    Aug 31, 2011
    Software Engineer
    Santa Clara, CA
    IMHO, it is only "sort of dumb". The way things are going, in a few years, a good light bulb may end up using not much more power than an electronic lighting control. In that case, having a neutral to power the control is probably better than relying on residual current through the bulb...
  10. hj
    quote; Those instances are very rare when you are starting from scratch.
    Not in my experience. Quite often the power feeds to the light fixture in the ceiling, and then 2 wires are dropped to the switch to control it.
Similar Threads: circuit/2 gang
Electrical Forum discussion & Blog 3 gang Insteon switch install driving me nuts~ Jan 17, 2016
Electrical Forum discussion & Blog Does ANYONE make a switch with MULTIPLE DIMMERS in 1 gang, for LEDs and 3 ways in decora/rocker?? Nov 8, 2015
Electrical Forum discussion & Blog 12/4 to run constant and switched receptacles in 2 gang boxes Apr 2, 2014
Electrical Forum discussion & Blog Using grounding bar inside 3-gang metal outlet box Mar 14, 2014
Electrical Forum discussion & Blog 4 Gang Switch Box Wiring diagram Mar 30, 2013
