1.5" Extruded Insulation
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by rmelo99, Dec 5, 2008.
  1. rmelo99
    rmelo99 Network Engineer
    Jul 7, 2006
    Network Engineer
    I need to find some insulation for a 1.5" steel pipe. All the depot and other places I look have are 1/2",3/4".
    Where can I get some of the foam stuff for 1.5"
    Thanks
    Rem
  2. frenchie
    frenchie Jack of all trades
    Dec 30, 2006
    Caretaker
    I've never seen foam for pipes that big.
    You can get fiberglass sleeves in the HVAC section that size - used for insulating heat pipes.
  4. hj
    insulation
    They make the larger sizes of foam insulation, but you have to cut it and glue it back together if you cannot slide it onto the pipe before installation. Most air conditioning suppliers and many plumbing supply houses will have it.
  5. kingsotall
    kingsotall Plunger/TurdPuncher
    Aug 17, 2008
    Hand copper part cleaned ready to go
    Flagstaff, AZ Sitting on an upside down 5 gallon b
    They have foam insulation for 2" pex so...
Similar Threads: Extruded Insulation
Plumbing Forum, Professional & DIY Advice Pipes above or below insulation with unusual insulated slab on grade Jan 31, 2017
Plumbing Forum, Professional & DIY Advice pipe insulation for cold water Jan 14, 2012
Plumbing Forum, Professional & DIY Advice Insulation ok? Oct 7, 2011
Plumbing Forum, Professional & DIY Advice Pipe Insulation Apr 28, 2011
Plumbing Forum, Professional & DIY Advice Shower Steam Generator Pipe in Contact with "Pink" Insulation Jan 30, 2011
