Squeak
In preparation for a new washing machine to be delivered, the handle on my cold water shutoff valve broke off. After some fiddling, I was able to figure out how to use a wrench to be able to turn it off and on -- but it is not ideal.
I would like to replace the valve (and since I am doing one, might as well do the hot as well). I am having a little issue figuring out what exactly to buy.
Based on this pictures (two from today, and one from when the house was built), the CPVC comes into the box, and looks like there is a transition to the brass right at the end there, and a valve is threaded into the connection. It is an Oatey valve and box, if it helps at all.
Is it just as simple as unscrewing out the valve at the top, and leaving the female metal connection attached to the plastic, and get a new valve to screw onto there?
Any recommendations on a high-quality part I can buy to fit here? Since I can shut it off with the wrench, I have a little bit of time to order the right part.
