1/4 turn valves to far a part???
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by NOPLUMMERHOMEOWNER, Nov 3, 2008.
  1. NOPLUMMERHOMEOWNER
    NOPLUMMERHOMEOWNER New Member
    Oct 22, 2008
    You all have been such a large help in the past I am hoping that you can again.
    Basicly, I have a small 1/2 bath or water closet. When we purchased the home the dry wal was baddy damaged and had holes all over. I have relaid new dry wall up on all walls except the main wall with the toilet, and the 1/4 turn valves.
    Well being a small bath room we have to get a small vanity. We finally found what we where looking for:
    http://www.*********.com/catalog/productImages/300/69/6937d903-97b4-4f8a-9ba4-0ffdf122b0cb_300.jpg
    I finally get it home and realize that the darn thing wont fit against the wall due to the "1/4 turn valves" are to far a part. How, Do I fix this?
    Or am I doomed to a standard vanity / pedistel?
    Please help.
  2. kingsotall
    kingsotall Plunger/TurdPuncher
    Aug 17, 2008
    Hand copper part cleaned ready to go
    Flagstaff, AZ Sitting on an upside down 5 gallon b
    Post some pictures of the situation. It is hard to tell what you are describing.
  4. hj
    valves
    I cannot imagine how the valves being "too far apart" would have any effect on how close the cabinet comes to the wall. How about a better description or a picture?
  5. NOPLUMMERHOMEOWNER
    Oct 22, 2008
    Ok, after reading my post i realized how much infomation I am leaving out.
    First, it is not the distance apart that is keeping it from getting against the wall. It is the fact the new vanity is not wide enough to accept them into the vanity. They are spaced so the left one as facing the wall is ok but the right one would require clearanceing the sicde of the vanity to the point where you could see the valve.
    THIS IS THE UNIT I AM INSTALLING:
    http://205.196.138.20//4/69/6937d903-97b4-4f8a-9ba4-0ffdf122b0cb_4.jpg
  6. maintenanceguy
    maintenanceguy In the Trades
    Aug 18, 2008
    Pennsylvania
    The only solution I know would be to open a small hole in the wall, cut some pipe and do some soldering to relocate where they come through the wall.
    Not a big or difficult job if you're a bit handy.
  7. NOPLUMMERHOMEOWNER
    Oct 22, 2008
    I went last night to a local plumming supply they sold me pair of new 1/4 turn
    valves and a pair of 90 degree elbows. The elbows are a new style that are self sealing and require a tool to remove them once installed.
    Are these ok to use?
    I have looked online, I belive that they are called GatorBite's or sharkbites depending on which "big box store" you go to.
  8. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Brand could be very important.
    There are a few different ones out there ranging from decent to junk.
    Why don't you post exactly what you have?
Similar Threads: turn valves
Plumbing Forum, Professional & DIY Advice Trying to install a new sink but can't turn off shutoff valves on old one... Aug 1, 2013
Plumbing Forum, Professional & DIY Advice changing out all the cheap plastic stop valves with 1/4 turn stops. Jul 29, 2013
Plumbing Forum, Professional & DIY Advice Red & White 1/4 Turn Ball Valves STILL OK to use? Jan 30, 2012
Plumbing Forum, Professional & DIY Advice Washer water supply valves won't turn Nov 1, 2009
Plumbing Forum, Professional & DIY Advice Which 1/4 turn ball valves to get? Sep 26, 2009
