1/2" tankless coil - what size supply lines?
Discussion in 'Boiler Forum' started by deltasmith, Oct 14, 2012.
  1. deltasmith
    deltasmith New Member
    Apr 18, 2010
    I have a boiler with a tankless coil that uses 1/2" pipe. Currently, the cold water supply line is 3/4" until about 10 feet from the coil, where it drops to half inch. The hot water piping coming off the coil and feeding every hot water sink and shower in the house is 1/2". I'm wondering if I should replace the supply and return piping with 3/4", or if there's so little added benefit likely to accrue from upsizing to 3/4" due to the 1/2" coil in the middle that I should focus on other likely causes of my problems with low pressure at the tap? Has anyone ever set up a 1/2" tankless coil with 3/4" supply and return? Is it worth doing?
Similar Threads: tankless coil
Boiler Forum Oil boiler with tankless coil quick question read all posts and need one more answer Jan 31, 2014
Boiler Forum Oil Fired Boiler With tankless Coil conversion to what? Jan 13, 2014
Boiler Forum Tankless Coil in oil fired Boiler doesnt produce hot water/ boiler doesn't turn on Jan 26, 2012
Boiler Forum Tankless Coil Dec 16, 2011
Boiler Forum Bypassing Tankless Coil in Boiler Dec 6, 2011
