1/2" copper to a 3/4" radiator!?!
Discussion in 'HVAC Heating & Cooling' started by bick421, Aug 19, 2009.
  1. bick421
    bick421 New Member
    Aug 19, 2009
    Hi,
    I am performing a bathroom remodel. Part of my scope of work requires that I remove a 2.5'x2.5' cast iron radiator, and replace with a 5' baseboard radiator. The system is hot water.
    The 5' baseboard (and the cast iron) are set up for 3/4" plumbing. The previous remodel employed 1/2" copper supply and return to the cast iron radiator. It seemed to work okay (with the c.i. radiator).
    My question is since I have it all ripped up, should i spend the time and money (~$50) to run new 3/4" copper service to the main system? The main system is 1" iron (i think? - the o.d. is 1.25"). I don't want to go through the effort if this will work just fine. I am concerned about head losses due to the changing diameters, and I don't want to discover a problem in January.
    The new baseboard is the 5' Slant/Fin model (3/4" copper tube w/ aluminum fins shrouded by a steel cover.
    Finally, the bathroom radiator is the only radiator supplied by these lines, which split off the main trunk line in the basement.
    Thanks for your help!
    Mark
Similar Threads: copper radiator
HVAC Heating & Cooling UK Radiator Valve and US Copper Pipe Feb 25, 2009
HVAC Heating & Cooling Torque wrench for copper lines? Aug 19, 2016
HVAC Heating & Cooling My house has all the copper baseboard going in a weird double loop. Mar 15, 2014
HVAC Heating & Cooling copper strapping hangers touching aluminum ducts Jun 21, 2012
HVAC Heating & Cooling Life expectancy of copper and black iron pipe Jun 17, 2011
