1/2 coper out of anode port
Discussion in 'Water Heater Forum, Tanks' started by mjackson, Feb 25, 2011.
  1. mjackson
    mjackson New Member
    Feb 25, 2011
    Manitoba, Canada
    hi,
    i have a 1/2 coper line coming out of my hwt and going into the ceiling im unable to trace where the line goes.
    just wondering generally why you would have a line into the anode port? there is 3/4" and both the hot and cold supplying the house and tied into the well pump
    thanks
  2. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    Does it get as hot as the outlet pipe does, suggesting that it supplies hot water to somewhere? Do you get instant hot water at any faucet? Do you have any in-floor radiant heat?
    It might be a return line on a recirc pump.
  4. hj
    The anode port usually has either an anode rod or a plug in it. The only explanation for what you describe is that someone needed a place to connect a hot water pipe and that was the easiest spot. WHERE it goes, howver, we cannot even begin to tell you that.
  5. jadnashua
    Removing the (sacraficial) anode from a WH could significantly shorten its service life. Depends some on your water quality. The anode gets preferentially eaten away rather than the steel lining of the tank. Remove it, and you are totally at the mercy of the quality of the liner. WIth it, even with a small defect in the liner, the anode gets eaten up rather than the tank. If you keep a good anode in the tank, it can last a very long time.
  6. mjackson
    mjackson New Member
    Feb 25, 2011
    Manitoba, Canada
    there is no radiant heat in the house and no instant hot water, Im gonna hook up a new tank and just hook it up the same way the old one was hooked up and hope for the best ;-)
  7. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    Jim is right, and removing the anode could void warranty on your new tank as well as shorten its life. Why not just cut a valve into the line and turn it off, then go around and see where there is no more hot water. Then you will be able to plumb it up right when you put in the new tank.
  8. ballvalve
    Dec 28, 2009
    northfork, california
    I do not believe the anode threads are pipe size. Finer. You might have a remote PRV somewhere?
  9. hj
    The anode is a 3/4" pipe tap. By the time the original anode has deteriorated, ALL exposed metal surfaces should already be coated with the anode's material. What do you mean by " hook it up tne same way"? Does that mean you will REMOVE the anode rod. That is NOT a good idea on a new water heater. There is no warranty issue with removing the anode rod, because when a heater fails under warranty, NOBODY looks at it. It goes directly into the scrap pile.
  10. jadnashua
    Maybe I'm all wet, but my understanding of a sacraficial anode is that because it is more reactive than the steel (iron) in the tank, it gets eaten away rather than the steel (iron). It ends up as ions and stays in suspension and is flushed out with the water as used. As opposed to a closed system like in a boiler, there is constantly new, reactive, air carying water being replaced in the tank, so it is an on-going battle to decide which part gets eaten up. So, like on bouys, ships, bridge abutments, and anything else that may be in water, keeping the anodes replaced and intact helps extend the life of the thing they are attached to. With anything, though, it is a losing battle, and eventually, while the corrosion is mostly controlled by the sacraficial action, some occurs elsewhere (in the tank), so it can't stop it forever. But, you can slow it down considerably if you keep a full anode in there. On a ship, and other big expensive items, they repaint them periodically...can't do that to the inside of your WH tank, but those ships, etc. would be a rusting hulk much sooner if they didn't have and replenish when required, their sacraficial anodes.
  11. ballvalve
    Dec 28, 2009
    Maybe the guy was bright enough to cut the anode off and just dropped it in the tank.
    If it would make a 'connection' to the tank is another question.
    They make outlet ports with the anode attached.
  12. mjackson
    mjackson New Member
    Feb 25, 2011
    Manitoba, Canada
    ok so i installed the tank yesterday and traced back the 1/2 line coming out of the anode port.
    the guy had ran 1/2" out of the anode port then into the crawl space where he Tees off and runs 1/2" line down around 25 feet to a bathroom and then ties back into the 3/4" right before it goes upto the fixture.
    the other side runs to the kitchen and then ties in the same.
    has anyone heard of this before? im guessing its maybe a trick to gain more water pressure?
    i have seen many suspect plumbing work in the house. Ie. bent nails as hangers touching the copper.
  13. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    Maybe he intended it as a passive return loop to get hot water to circulate.
Similar Threads: coper anode
Water Heater Forum, Tanks Anode Rod Aluminum broken in two; can't get rod out of tank! Feb 11, 2017
Water Heater Forum, Tanks Anode rod under hot outlet? Ao Smith GVR 50 300 Nov 1, 2016
Water Heater Forum, Tanks Preventive Maint & Anode aftermarket or OEM only? Oct 18, 2016
Water Heater Forum, Tanks Any idea how many anode rods my new Reliance WH has? Nov 6, 2015
Water Heater Forum, Tanks Anode rod question Sep 3, 2015
