1 - 1/2 hp irrigation pump rebuild?
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by hygron, Aug 8, 2013.
  1. hygron
    hygron Member
    Jan 29, 2010
    Grrenhouse proprietor, Hydroponic/Fertigation Syst
    Hell Hole Swamp
    I have a big 1-11/2 hp irrigation pump I need to fix. Motor is good, but impeller seems to be froze up. Need some guidance, before I tear into it and mess something up.
    I can take a picture, but I am not sure I can tell what brand this is.
    When I turn on the breaker to run pump; It makes an electrical hum sound that leads me to believe it would turn the shaft if it were not locked up. I did not want to pull the impeller head until I asked if there was anything to watch out for, when doing so. Thanks Guys
  2. DonL
    DonL Jack of all trades Master of one
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    Be best to clean the trash out of it, It may be that simple. Rotating the motor backwards may help.
    If you do not know the model then parts will be hard to find. You will need new seals, at minimum, if you take it apart.
    Trash in the impeller can lock one up. Maybe could be the start switch, or a cap if it uses one.
    Watch out for electrical Shock. Kill the power Power first. (You asked, be safe)
    Good Luck.
  4. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    I also think the start switch, start cap, or both is more likely the problem than and impeller locked up.
  5. masterpumpman
    masterpumpman New Member
    Mar 26, 2007
    Consult and Teach Well Drilling Internationally
    Virginia Beach, VA
    Valveman said it best, it's more likely the start switch or the capacitor. Remove the cap on the rear of the motor and turn the motor shaft. If it turns free it's most likely that the pump end is OK.
  6. hygron
    hygron Member
    Jan 29, 2010
    Hell Hole Swamp
    Thanks all.
    So you say that even though the starter switch is possibly bad; power will get to the motor to produce a binding type electrical hum? Just clarifying, because on my HID lamps; If a starter is bad...No Juice, noise, etc...DEAD
    How does electricity get through a bad starter to the motor? Just asking, not disagreeing.
  7. hygron
    hygron Member
    Jan 29, 2010
    Hell Hole Swamp
    This is what I was looking for. As always the supporters of T.Loves forum are right on, and very easy to understand.
  8. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    Most motors have a centrifugal switch that when closed, energizes separate start windings and opens when the motor gets up to speed. The run windings can't start the motor and so they just hum.
  9. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    What voltage are you trying ?
    You may want to check the voltage setting while you are in there.
    Good Luck.
  10. hygron
    hygron Member
    Jan 29, 2010
    Hell Hole Swamp
    Thanks again guys. Ok. i understand the circuit now.
    As far as voltage; We were running 220, and pump worked for almost 2 years. But, thanks, will check the voltage too.
Similar Threads: irrigation pump
Pumps and Tanks Well Forum & Blog. Water is life. Irrigation pump not working May 28, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Two pumps one irrigation system Dec 31, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Pump for a small scale drip irrigation system? Aug 24, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Question About Pump Pressure To Irrigation System Jul 26, 2014
Pumps and Tanks Well Forum & Blog. Water is life. Irrigation pump loses prime overnight Aug 26, 2013
