1-1/2" deep multi-gang electrical boxes
Discussion in 'Electrical Forum discussion & Blog' started by Lakee911, Jan 14, 2008.
  1. Lakee911
    Lakee911 I&C Engineer (mostly WWTP)
    Aug 23, 2005
    Columbus, OH
    Hey fellas,
    Does anyone know of a manufacturer that makes multi-gang (2, 3 or 4 gang)electrical boxes that are 1.5" or less deep? I need them for a basement remodel. 1" furring strips are being used over a concrete wall with 1/2" drywall over that.
    I did find some 1-1/4" deep single gang boxes, but they're limited to only single gang. :(
    Thanks,
    Jason
  2. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    use either a 4 square or a 4 11/16 with a 1/2 plaster ring.
  4. Lakee911
    Aug 23, 2005
    Columbus, OH
    If I use a 4 square, I'm unable to mount any devices as they only have screws in the corners and they're 1.5" deep.
    Where can I find one that is 1" or 11/16" deep?
    Thanks,
    Jason
  5. jwelectric
    Jun 14, 2007
    Instructor
    North Carolina
    sorry I should have said flat plaster ring and a jumbo plate cover.
  6. jwelectric
    Jun 14, 2007
    Instructor
    North Carolina
  7. Lakee911
    Aug 23, 2005
    Columbus, OH
    That first link won't look very nice in a finished basement. The second link doesn't work and the third is 2" thick. :(
    Any other ideas?
    I'm afraid I'll have to chip out the concrete behind a 2" device. :(
    Thanks,
    Jason
  8. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    1 1/4 is awfully shallow, can you fur the wall out a touch more? You are going to struggle with every receptacle and switch you install...
  9. jwelectric
    Jun 14, 2007
    Instructor
    North Carolina
    The third can also be bought in a depth of 1 1/2 inches.
    I am giving you ideas not gathering material for you unless you have a check with my name on it and then if there is enough zeros on it I will even make the installation for you.
  10. Alectrician
    Alectrician DIY Senior Member
    Jun 15, 2007
    Simply tell them to properly fir it out 1 1/2" and do it with standard shallow boxes.
    If it's a basement I don't think you are supposed to chip out block.
  11. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    The problem your going to have even with 1 1/2 boxes is box fill, the way I see it is a 3x2x1 1/2 box is good for 7.5 cu. in., a 14-2 alone is 6 cu. in, so you wont even be able to install a device and make code... They make a 4" sq. by 1 1/4 which is good for 18 cu in plus the plaster ring... Your going to have to fur the wall out to meet code IMO.
  12. Lakee911
    Aug 23, 2005
    Columbus, OH
    That's kind of harsh, jw. That third one does not, from all the research that I've done, exist in a 1-1/2" depth. So, I challenge you to find me one.
    As for the boxes that are made to accept a flat plaster ring that are 1-1/2" deep--that could work. I'll look into that.
    Otherwise, I'll just fir out the wall a little more and use a standard box.
    Thanks for your help, jw and everyone!
    Jason
  13. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    I personally would have just framed the walls with flat 2x4's, not sure of your building codes and insulation factor, but that could be a whole other issue...:D
    [​IMG]
    You can get these in 1 1/2 so with a 1/2 in plaster ring you would be fine. if you fur the walls out to 1 1/2 hope this helps you out.
  14. Lakee911
    Aug 23, 2005
    Columbus, OH
    Hey Chris,
    That is a good point, but Carlon makes a box (http://www.homeandbeyond.com/prod-0010802.html) that is 1-1/4" deep and it's rated at 8" cu in. I've commonly heard that reffered to as a "switch box" and I believe their website says that it meets code for a switch or a receptacle. It has the UL stamp too. Anyhow.
    1 14/2+G: 1*2*2+1 = 5
    1 Yoke: 1*2 = 2
    5 + 2 = 7 < 8.
    I believe no clamp is needed for a 1G box. So, is that math ok? I would think that a 2G box that's 1-1/2" would be at least 19.2 cu in. Even 18 shoud be ok though.
    2 14/2+G: 2*2*2+1 = 9
    2 Yokes: 2*2 = 4
    2 clamps = 2
    9 + 4 + 2 = 15 < 19.2
    What do you think?
  15. Lakee911
    Aug 23, 2005
    Columbus, OH
    Ok, everyone replying all at once! I guess I can't say I'm not getting help. :) I'm going to try that box, Chris with the flat plaster ring. Thanks.
  16. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    14-2 w ground would equal 6 cu in, 2 for the black, 2 for the white, 2 for the ground...
    device (yoke) would be double volume allowance, based in largest conductor supported by the device. = 4
    I would say ney on the cable clamp,
    so your up to 10 cu in...
    so with a 4" sq new work plastic at 18 cu in, you could have 1 device, and two cables in the box and still be okay.
  17. Lakee911
    Aug 23, 2005
    Columbus, OH
    You're right ... the grounds are all counted once, but still multiplied by the 2cu in per conductor for #14. So that makes it 8.
    I don't see how the device would be double volume allowance though. It should only be 2 for a single device, no? I'm not arguing (for once)...just trying to learn :)
  18. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    if you take a look at 314.16 (B)(4) Device or Equipment Fill
    For each yoke or strap containing one or more devices or equipment, a double volume allowance in accordance with Table 314.16(B) shall be made for each yoke or strap based on the largest conductor connected to a device(s) or equipment supported by that yoke or strap.
  19. jwelectric
    Jun 14, 2007
    Instructor
    North Carolina
    Didn't mean to sound harsh I meant it to sound funny.
    Looking for one of those 1 1/2 inch deep go to Lowe's Home Improvement on highway 64/49 Asheboro, North Carolina and they have them by the case.
  20. Lakee911
    Aug 23, 2005
    Columbus, OH
    We got a winner!
    Ok then. Ha ha :)
    Ok, so I went to bLowes, in Columbus, OH and I measured these boxes. Unfortunately, these are measured 1.5" deep from the inside and once you add the back and the plaster ring they are approximately 1-11/16 deep. Boo
    So, I thought that another option would be to use a plastic 4"x4" box and sand or cut 3/16" of an inch off the face to make up for the added height. This would doable, but not ideal for more than a box or two.
    I did, however, stumble upon this Raco box (http://www.myproship.com/index.aspx...38bfb9907b33d920d4&tab=13&Qtype=1&sku=6228373) at Lowes. It is exactly 1.5" inches deep, on the outside, and it is gangable, if that is the correct term. A screw comes off the side and the side comes off. Multiple boxes can then be attached to eachother. You can put as many together as you would like. The plaster ears come off too to make a standard box. They're $1.98 each.
    So, ok I'm good. I'm done. Thanks! :)
  21. Lakee911
    Aug 23, 2005
    Columbus, OH
    I'm not sure I understand that, but my code book is at work. I'll look at it tomorrow. Is that 2008 or 2005?
    Jason
