1 1/2 copper to PVC help
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by coopns, Jun 26, 2010.
  1. coopns
    coopns New Member
    Sep 25, 2006
    Massachusetts
    Coming out of the wall I have 1 1/2 copper (see pic). The trap/drain didn't line up with my new vanity/counter top. So I cut off the exisiting copper w/trap. I got the 1 1/2 inch male.
    [​IMG]
    [​IMG][/IMG]
    So do I solder that male on and then attach a flexible drain kit found at HD or Lowes?
    Advice or recommendations?
  2. Terry
    Aug 17, 2004
    What you want is a "Marvel Ring"
    It's a brass threaded threads that solder on. Much smaller then a male adapter.
    I couldn't find a picture to show you but they are about 3/8" long.
  4. coopns
    coopns New Member
    Sep 25, 2006
    Massachusetts
    So what I currenty have, won't work with flexible drain kit?
    1. So would I ask for a Marvel Ring at HD or Lowes or does it go by a different name? (I often have trouble finding adequate help there).
    2. After I solder the Marvel Ring on, then attach the flexible drain kit?
    Thanks.
  5. Terry
    Aug 17, 2004
    I missed the part about a flexible drain.
    I've never used one. I've always used a standard p-trap with slip joint nuts.
    Which would work with either the marvel ring or the male adapter.
    I doubt that the box stores would have any idea about the marvel ring, that's a pure plumbing thing.
  6. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Don't even consider the flex drain. These are a gimmick sold only to DIY that don't know any better. The reason you want the Marvel Ring instead of the standard male adapter is the adapter sticks out too far to cover. It would function just fine, but not too attractive. You can use a PVC drain kit, just not the flex one, or a chromed brass one. The brass will cost a tad more, but they certainly are more attractive than PVC. As noted, you'll have to do to a "real" plumbing supply rather than a Big Box Store for the Marvel Ring.
  7. Doherty Plumbing
    Doherty Plumbing Journeyman & Gas Fitter
    Jun 22, 2009
    Red Seal Journeyman Plumber & Licensed Gas Fitter
    Penticton, BC
    Why not use a 1.5" copper x 1.5" IPS bow adapter? Or even a 1.5" copper by 1.5" IPS banded coupling?
  8. wallskev
    wallskev New Member
    May 14, 2009
    Manufacturing Consultant
    North Carolina,USA
    Marvel Rings are available from http://www.coburns.com if you cannot find locally.
    http://www.coburns.com/Products/Details.aspx?Item=331876
    274-6 ADAPTER BRS 1-1/2 FM SWT X SJ THRD MARVEL RING ( FLUSH ADAPTER ) CAT451S
    Product Details:
    Manufacturer Name: SIOUX CHIEF MFG.
    Coburns#: SIO2746
    Manufacturer#: 274-6
    Price: $5.71
    Availability: 449
    Product Description: 274-6 ADAPTER BRS 1-1/2 FSWT X SJ THRD
  9. coopns
    coopns New Member
    Sep 25, 2006
    Massachusetts
    So I can use that male adapter with a PVC drain kit? I don't mind if it sticks out a bit far, it will all be hidden behind the vanity.
  10. Terry
    Aug 17, 2004
    Most plumbers are using the standard 1.5" p-traps that come with both the 1.5" slip joint washer and the 1.5 x 1.25 reducing slip joint washer.
    It's all good.
Similar Threads: copper help
Plumbing Forum, Professional & DIY Advice Help with Copper Pipe Support Jan 15, 2017
Plumbing Forum, Professional & DIY Advice Help soldering a split copper fitting Dec 28, 2016
Plumbing Forum, Professional & DIY Advice IKEA, Help connecting with 1-1/4" copper stub out Aug 17, 2016
Plumbing Forum, Professional & DIY Advice Soldering brass to copper help....PLease! Nov 25, 2010
Plumbing Forum, Professional & DIY Advice replacing old pipe.....need help picking out what to use....CPVC, PEX, Copper??? Jun 14, 2010
