View Full Version : Shower & bathtub Forum
Pages :
10]
11
12
13
14
15
- Maax vs Aqua Glass?
- Bathtub faucet drips - how to stop?
- Shower slide bar
- Shower faucet problems
- Price Pfister Single lever shower NO COLD!
- Pro and con of building a shower cubic in basement
- Old Brass Drain
- loose shower door handle
- tub, wall, wet carpet.
- attaching tile to fiberglass shower base
- hardibacker screw
- shower diverter problem
- Water hammer in the shower
- Overflow knob removal
- Can't Identify Shower Brand
- I Need Price Pfister OLD Flowmaster parts
- What style shower/bath faucet is this?
- Replacing shower valve
- New Pan Installed
- Best finishing process for tub/shower inserts
- Fiberglass tub/shower concern
- Can someone identify the model of this delta faucet
- Fiber cement board (hardibacker) question
- Kohler Portrait Jetted Tub
- Shower Fixture Removal
- Adding a tub and sink in basement
- Labelled index buttons for faucet handles
- Shower head leak. While in off state (Moen)
- Problems with Replacing Shower Flange
- 1/2 story bathroom remodel
- Shower leaks when the lower faucet is on?
- new sterling bath damaged by bodysoap
- Can someone tell me how to remove this handle?
- glass mosaic tile advice
- Lifespan for Cast Iron Tub?
- Low hot water pressure with Mixet shower/tub faucet
- grouting tile
- Add additional trap to tub drain????
- need drawing/pic of tub/drain/trap setup.
- Leaking valve - new water tank
- glass tile
- Shower
- Problem installing new tub drain
- Installing one piece Fiberglass tub and shower
- building a shower curb with composite pan
- New Kohler Water Tile: Good or Bad
- convert to non bevelled faucet
- Got a Bad Leak
- Installed new shower arm and I get a small leak.. is this OK??
- Americast tub any good?
- Advice re:tub removal
- Leak under side of old tub -
- Leak in Shower - Plumber's Visit
- Claw Foot Cast Iron Tub removal
- Type of supply pipe to shower valve.
- vanity faucet brand?
- cast iron plumbing
- size of a stand up shower
- Stop the water!!
- Drilling Holes in fiberglass Tub and Shower
- Cement board over drywall
- Bootz Industries Bathtubs?
- Any suggestions on removing this shower handle?
- Starting on my second bathroom, shower valve ?
- Rusting porcelain coated tub.
- New Install is leaking PLEASE HELP!
- Replace tub/shower faucet
- Remove frozen bathtub drain
- Leaking Moen Bathtub Spout Diverter
- Constant Dripping From Shower Valve
- Which Shower Valve is best?
- Low flow Woes...Suggestions?
- Can Price Pfister valves be adjusted?
- handheld shower head attachment from which you can shut off water flow?
- Problem with New Tub Spout
- changing polished brass tub fixtures
- Candle wax down drain
- Shower/tub plumbing
- Shower handle
- Pro for tub drain?
- Bathtub Faucet Issue
- Shower Drain Vent?
- No water pressure on hot side in shower
- leak in Delta 13 series shower
- ought to be in the smithsonian
- P-trap distance from drain
- Proper Vinyl Pan Install
- Hand held Shower recommendation?
- Mortared shower pan on slab foundation
- Bathub leak by rusty drain area
- Removing old Delta spout / diverter
- Question about slip-joints
- Problem with r/o shower drainin slab
- 1925 shower drain SLOW
- Uneven basement floor, how to install shower?
- product called 'just for copper'
- Delta "thermostatic" worth it?
- Loud dripping in shower drain
- Need help replacing shower drain base
- Please help, my tub is leaking under my house
- blistering fiberglass tub unit
- low profile overflow
- Looking for a small tub.
- Vent problem???
- Replacement mixer valve body too big for wall space.
- Fiberglass "pebbling"
- floor mount tub filler...
- leaking shower head
- Groaning pipes
- brass/abs connection
- shower with header tank
- towel hanger removal
- American Standard Ultra-Mix Pressure Balancing Bath and Shower Set Model 1363 Series
- Price Pfister Shower Value
- faucet removal
- steam shower
- cpvc shower head stubouts
- Manufactured Home Tub Pond
- Changing drain size
- Tub Surround Advice
- 30" Outside Diameter Shower Enclosure?
- Lyons Tubs?
- Low Water Pressure in BathTub
- Newbie needs help with drain
- Mstr Bth Shower Pressure Low - Fine Elsehwere
- Which comes first - tub or floor?
- Kohler Villager vs. TOTO FBY1525 Tubs
- Am Std or Jacuzzi???
- No hot water in bathroom sink
- Tub type for an apartment?
- Shims or start over?
- toilet flange question
- American-Standard push/pull tub and shower valve
- fiberglass thickness
- Water Temperature and Pressure
- Need Whirlpool Recommendation from the Pro's
- Tub Waste Shoe Leak - Fine thread pipe?
- Tub support?
- New Tub Problem- won't get clean!
- Last row of tile above shower base
- Valve Cartridge Question
- Hardi board over drywall?
- drain and copper lines for a new tub install, ideas...
- Planning a Steam Shower
- Mustee Durabase shower base installation
- Moen shower just stops
- sterling bathtub/wall surround unit-HELP
- Installing thermostatic mixing valve
- To Replace shower valve or NOT to replace shower valve
- Bathtub copper trap replacement.
- drain care causes more backup?
- max p trap distance from tub drain in arizona??
- HELP: Replacing Balancing Spool Kit
- Hot water takes too long to come out at all!
- I'm P-trapped in misery
- Tub faucet leaking
- Looking for tub w/ tile flange but no apron..
- Thermostatic mixer with headshower
- Water shut off
- Vertical Spa Recommendations
- Shower Stall Light
- Looking for Lasco shower/tub parts
- Will this rough-in work?
- Is Danze any good?
- Flow rate mystery
- hansgrohe rough in for tub filler, how to set???
- Tub faucet too short!
- Whirlpool Problem
- Kohler K839 "Maestro" tub--opinions?
- Fluxuating water temperature
- erratic water pressure
- replacing shower faucet
- Installing Mixet shower faucet
- Pressure balance valve required in Arizona...
- Wierd shower drain set up
- Recessed marble tub top problems?
- Juncture of tub and separate shower
- leaking delta 1700 amature repair
- How to finish the nailing flange on shower insert?
- Moen Tub/Shower faucet won't stay shut off>
- Neo-Angle Shower Door
- older Moen tub/shower valve leak
- remodelingwalkinshower
- Tiling around Tub Surrond
- new shower
- new tub/drain question(s)
- How do I figure what size shower to replace tub.
- Shower: insert or tile?
- Shower stem leak
- installing drop in tub
- Price pfister type R89-70XC Single Control valve shower leak and too hot mix
- Moving a tub drain
- Sterling Esemble Tub
- Replacing Shower Trim
- Wet Bathroom Walls and Ceilings
- help! we need a good showerhead!
- Price Pfister faucet conversion
- Sterling Vikrell 48" Receptor - Door Help
- Faulty Faucet?
- 32" Neo Angle Shower unit
- chrome gooseneck to cpvc shower fitting - how do I ensure it doesn't leak behind the
- Thinset Thickness
- Moisture on Outside of Bathtub
- Split Durock Seams in a Shower wall?
- tile shower install
- Delta shower faucet opinion
- Steel, styrene, fiberglass or acrylic ... which is best for replacement tub?
- Opinions on AquaBrass for Master Bath Shower
- Bathroom Reno
- Need to buy acrylic tub surround
- Framless glass shower enclosures?
- Shower drain relocation through joist
- Overflow clearance problem
- Correct size for Thermostatic valve and controls
- Bath Spout Diverter Problem
- Styrene base over old tile floor?
- Bathroom remodel
- Bathtub Clogged, Can't get cover plate off (no screws)
- The Parisienne l Headrest/Bath Pillow
- Remodel of Shower (Shower Pan Drain)
- shower stall seat
- Need Help!!!
- Bain Ulta Bathtub
- Shower/Tub Screens (or shield)
- What solvent/cleaner to remove duct tape adhesive from acrylic tub?
- Gray Out
- Installing Repcal valve seats
- Need help. Press-in faucet seats.
- Shower Flange
- Confused about 1/2 or 3/4 inch valves
- Moen Shower Faucet Leak
- Bradley Shower low pressure hot water side
- Shower Valve on a Different wall than head?
- New Bathtub Install
- water coming from spout and showerhead
- Help with connections at one handle valve! At wits end...
- Solder supply lines to valve or use threaded?
- Plumbest Brass No-Caulk Compression Drain
- Shower rod--no press-fit.
- Grout on shower base
- 3-handle to single conversion
- Will two seperate valves give better PSI?
- Framless glass shower without loosing an arm or leg?
- Urgent Problems Converting Tub To Walk In Shower
- Urgent - Help reducing shower drain height
- What to do about damaged walls behind tiles?
- shower knob broke and Powers is brand name
- mortar under tub
